Washer has been having issues with spinning. I had to stop using the extra rinse cycle, it worked for a while and now it wont spin at all. I pulled it apart and checked the drive coupling and that is fine. Dont know where to go from there. Thanks!
Motor comes on and it sounds like its spinning, but the basket does not move. Even if i move it by hand to begin with, which used to work.
It’s probably the clutch.
— Begin quote from magician59;196974
how do you get at the lid switch?
