Washer won't spin
My washer will not spin. I have depressed the lid switch manualy with the lid open and the motor seems to run and sound just fine but it will not spin. It seemed to start doing this all of a sudden. Can anyone help?:slight_smile:
You probably have a bad clutch. Usually, if there is complete clutch failure, there are other problems like something stuck in the tub, or jamed brake shoes. Get info on this in my sticky above "replacing direct drive brake shoes" for info on this.
