my washer will not spin? it leaves the clothes soaking wet? it will drain and everything but will not spin at all? and i cant seem to find the belt? can someone give me some advice here? thanks
With the motor running in spin, you probably have a bad clutch and either bad brake shoes, or something stuck in the tub.
Go to my "sticky" (replacing direct drive brake shoes) for help with this. Post results.
