Won't spin
My washer will not spin. Everything else works fine. If we continue trying to get it to spin, eventually it will. Fills, agitates and drains fine.
— Begin quote from PaulCM;303862
Paul,
you most likely have a slipping clutch/brake assembly,
[part]AP3094537[/part]
Everything else sounds good(timer motor pump).
Here’s a copy of the procedure from the APP Repair Forum archives,
So you’ll have a good idea of the procedure.
http://forum.appliancepartspros.com/washer-repair/3265-replacing-direct-drive-washer-brake-shoes.html
Good Luck,
