Washer goes through the spin cycle with one load and then stops going through the spin cycle and you could hear the water getting pumped out but does not spin. After trying several times to get it spin and drain it works again. Then stops again. Please Advise
Here is a guide that will tell you how to trouble shoot it. Start by resetting the codes, a lot of times that will fix things.
