Washer Works, but Clothes Remain Somewhat Wet.
[SIZE=5]Maytag Extra Large Capacity Heavy Duty Washer appears to be working fine. The exception appeared about a week ago where the clothing remained wet upon the completion of the cycle. A slight burning smell coupled with a brief squeaking noise has been encountered about three different times towards the end of the cycle. Any idea as what may be the issue? [/SIZE]
Replace both belts and lube the motor mount. It will be like NEW!!!:slight_smile:
Check for an article of clothing stuck between the tubs (at the top of the tubs, Put your hand between them and run your hand around that gap.:slight_smile:
