Clothes are sopping wet when the come out of washer. please help. thanks !
This is what I have done so far.
balanced machine.
replaced belt.
removed pump and checked for damaged impeller.
removed outer drum (shield between basket and drum) and agitator. Did not removed basket but added water, slashed around and tilted to see if i could see anything in there. looked ok. and there initially was a little water just in the bottom, maybe an inch.
ran diagnostic routine and calibration routine per video on you tube. came up clean.
when i changed belt over i did look at the pullys, they didn’t appear obviously loose. should i check again??
any ideas?
I guess what I am thinking about now is finding out how long each cycle is and make sure that they are the correct time.
does the diagnostic routine test RPM on motor?
thanks in advance for your help.
