Washer
Cold water will not fill machine. Is there a internal water valve and how do I replace it.
The model number posted doesn’t pull up. Please verify.
Most likely it’s the water valve, but check your screen inside the valve where the main cold hose hooks up. It could have sediment. Use a cloth or q-tip to clean it if it does and try it again.
Nat
