washer
I have a washer that started making bad noise everytime it would wash and spin and now it won’t turn and its leaking water from somewhere
I suspect your tub seal has failed, and water leaked into the transmission and it failed.
Here is a service manual on your model and her is a tech bulletin on the seal
http://www.servicematters.com/maytag_library/docs/16026502.pdf
http://www.servicematters.com/maytag_library/docs/TDL-0086-B.pdf
Replacing the machine may be the better and more economical solution.
