Washer
Iam needing information on putting the trans. shaft along with trans. and motor attacthed back into basket. The shaft go so far then stop. It feels like a lip is preventing me from popping right in. Please help me!
I would take off the motor as it makes it easier to work with the transmission.
You are probably have the brake release cam (that white plastic thing) hit the clutch spring. Slide the transmission in and then gently push on it while turning the clutch. and wiggling the transmission. You should be able to get it to in snug up against the screw holes.
Good luck, hope this helps.
