washer
washer does not work no lights on control panel there is power to back of control boards
If you are sure you are getting 120v to the board (pins 4 and 2 on connector p16) then you should probably replace the board. See the manual.
Here it is.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
