Im trying to determine what is causing a leak under the front panel of my washing machine. It only leaks when the machine is running. When off for awhile it doesnt leak. Thanks for your help in advance.
Very likely the problem is a bad drain pump. You have to remove the washer cabinet to find exactly where water is coming from. The instructions are attached to the reply.
- The pump [part]AP2907492[/part]
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LSC8244DQ0 | AppliancePartsPros.com
