Washing machine
I just finished doing a load of laundry…I reloaded another load and it won’t start…completely dead. Any suggestions would be greatly appreciated.
First thing to check is if there is power to the outlet.
Next with the lid closed try the timer at different wash and spin locations to see if there is power anywhere in the system. Perhaps there is a problem with the water level switch and that is why it will not fill. But you should still be able to get the unit to spin.
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203953319.pdf
