Water dispenser leaking?
Hello, When I get a glass of water from my side by side whirlpool it dispenses fine but when I’m done a pull my glass away I hear a tick tick tick and it drips water out for a few seconds. How do I fix this?
Probably a water solenoid going bad. Pull the back panel and measure the water solenoid voltage, (the solenoid that activates the 5/16 line) while someone pushes in the fountain water button. Valve should stop water as soon as voltage goes away, if not replace it. They sell a good kit for this P#
4318046. Just make sure you do not get the valve type with the push on water lines.
