Water Dispenser
The water suddenly quit dispensing. Smart Filter was checked and replaced with no solution. Water is pumping to disconnect located below freezer door when it was disconnected and dispenser lever depressed. Is there some sort of water solenoid valve located near the dispenser controls that controls water flow that may be out?
