When my machine goes into the spin cycle the water drains very slowly and I have to run through the spin cycle several times to get the water out of the machine.
Could it be the filter? The pump turns and the tub spins well enough.
The belts are loose but if there was a problem with tension then it would not spin which it does well.
[SIZE=5][/SIZE]
[SIZE=5]Gene, [/SIZE]
[SIZE=5][/SIZE]
[SIZE=5] Thank You Sir! I will be preforming surgery on the washer this evening once I’m finished working. Sometimes just a few words can save a person a lot of trouble and this is the case here. [/SIZE]
[SIZE=5][/SIZE]
[SIZE=5] Very Best Regards,[/SIZE]
[SIZE=5] Blues[/SIZE]
[SIZE=5][/SIZE]
[SIZE=5][/SIZE]
[SIZE=5][/SIZE]
[SIZE=5][/SIZE]
