Water overflowed as wouldn’t stop. I turned off the water supply. I then triggered the cycles to drain water from the tub. I turned water back on. I turned the washer back on and now tub will not fill. Help!
Did you completely drain the water from the tub? If you didn’t drain the water far enough, the water level pressure switch will not reset.
Eric
— Begin quote from fairbank56;799946
Eric
I did fully drain all the water…help!
Remove the front panel and check the air dome and hose on the lower left side of the tub for gunk. Pull hose off air dome to clean out any gunk and use a turkey baster with hot water to flush out the air dome. Be careful you don’t break the nipple off the air dome, the air dome is not removable/replaceable.
Eric
