Water leak in ice maker
Hi,I owned a MZD2766GEW forapprox. 5 years and just hooked up the ice maker. Tested the connections by running water through the dispenser for 10 min+.No leaks,but a lot of noise.When I turned on the tce maker switch(block),ice formed,but the unit leaked under the icemaker compartment after returning back to water dispenser.What happened and how to fix? Thanks for your help.
brown4repair
I have chased the same problem starting with water fill setting, and new ice maker. The problem is that the seal in the ice maker solenoid valve failed. There is a single water feed to the door water and ice maker solenoids so when the door water is used water is allowed to flow to the ice maker at the same time. You can verify this by opening the door, holding the interior light switch, activating the door water and watching for water flow. Hope this helps.
