Our washer leaks water but only sometimes.I haven’t taken any panels off to see where the water is coming from but I was curious if anyone else has had this problem and what the problem is and what was done to correct it
— Begin quote from jtown;681710
Hello . This is what I find most of the time , when the complaint is sometimes it leaks, when you open the door , and look at the bottom of the glass door more than likely you will find a dirty spot , that needs to be cleaned, this usually will consist of some hair , that when you close the door, it sometimes will let it leak thru the boot[AP4379904](https://www.appliancepartspros.com/search.aspx?p=[AP4379904](http://www.appliancepartspros.com/Appliance-Parts/whirlpool-door-boot-seal-item-number-ap4379904.aspx)) if it is clean you will need to check the door boot for a very small crack. Thank you and good luck !
