Whirlpool duet HT
Greetings,
My washer has decided to leak a little bit. This started last weekend and it leaks on the front, sort of. I first thought it was coming from the door, but further inspection proved me wrong. The water is coming from somewhere on the lower portion of the front. I will try to remove the front panel today, but thought would ask here if this is the end of my machine. I sure hope not.
Thanks. Be well
Miriam
Hello. The first thing to check is on the glass part of the door , is it clean ? clean it with windex or some other type cleaner , as long as you are sure it is clean , you can also run this thru the unit, [part]AP4320055[/part]
to help, next option would be the door boot bellow, be sure to include the correct model number of your unit in your next post it can be found inside the door usually on the left hand side thank you and good luck !
Thank you Gary for your reply. The glass is clean as I clean it regularly. I think that the door boot may be the issue here. I will check it tonight. Perhaps I will try to find some of the cleaner as well. The model is GHW9400PW4.
Once I check the door boot I will report back.
Thanks again. Be well
Miriam
Hello . Thank you the reason I ask you to check the glass is there is one spot right in the center of the bottom of the glass where I have seen it many times just a small amount of hair cause one to leak, any way here is the part # for the boot [part]AP3597347[/part]
