water level
My washing machine will only fill to the small water level,i have replaced the water level switch, it did not fix the problem
I did not get your exact model number to come up, but it appears you have a motor with a diagnostic on it. The error codes are generated by a flashing green light.
See if you have an error code, but before doing anything clear the codes. Sometimes that is all you need to do. Here are instructions.
http://www.appliance-repair-it.com/GE-washer-repair.html
