Water line into filter leaking.
Wondering if anyone can guide me on how to remove a panel in my fridge. The water line needs to be replaced that runs between the inlet valve and water filter (it is cracked and leaking). I have isolated the part which is w10678712, the water line, and have ordered it. But it appears to require that I remove the top panel from inside the fridge to get to the connection. It is the panel that holds the water filter housing, which when facing the fridge it is on the top right. There are two screws near the forward part of the water housing which I have removed but it is still secure. No other screws visible, so it looks like the removal is just a matter of clips on the inside and I just cannot tell where they are or how to remove the panel without breaking something. Any guidance? Model is wrf736sdam11 and it is a Whirlpool French door unit with the freezer on the bottom.
Thank you for any guidance!
Bentley
