Water not shuttig off once filled.
When washer is turned on water starts flowing on desired load but once it has filled it will not shut off water keeps flowing. can you please tell me what the problem is and name of part …
Much Thanks
Robert Ortiz
If the water will not stop when the machine is manually shut off, your water valves are stuck and need to be replaced.
If the water will stop when the machine is switched off, the problem is either with the tub connecting the tube to the water pressure switch or the switch itself. Clean out the tube, and if that does not fix things (it probably will) then replace the switch.
