Water Overflowing
My lid switch went bad and I replaced it. But the next time I loaded the washer it kept filling until it overflowed. I watched it several more times and the water flow will not shut off on any levels (small, medium or large) it just keeps filling. I read a blog that said it could be one of two things causing this problem. First the water level switch or second the water inlet valve. It stated that if you turn the machine on and start to fill it and unplug the machine and the water stops it is more than likely the water level switch. It stopped filling when I unpluged it. So I am guessing it’s the water level switch. I read on this forum that it could be a hose that needs to be blow out. Can you tell me where the switch and the hose is located? Thanl you
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GLWS1339es0
Water level switch is Item F5 (5) in Section 4.
Odds are you accidentally unplugged the hose either at the switch or at the tub end. Probably the switch as you did not say the un itwas leakink water under the unit.
Below is my standard reply for water valve problems:
This switch is actually a pressure switch. It has a tube that runs down to the bottom of the tub, as water fills the tub, air is trapped in the tube. As the water rises, the air pressure in the tube increases until it reaches the switch’s set point then the switch activates turning off the water and starting the agitate.
Possible problems.
  1. Gunk blocking water from entering the tube. Remove the tube at the switch and blow into it to clear the plug.
  2. Cracks or holes in the tube allowing the air to escape. Inspect the tube.
    In your case it may have been pulled off the switch.Also check that it is tight on the switch, if not, cut off half an inch and re-seat it.
  3. The switch is toast. Get a piece of tubing with the same internal diameter and attach this to the switch. Start a fill, then blow into the tube. You should be able to stop the water flow without blowing very hard.
    If you cannot stop it the switch is toast.
Note: That you may be able to stop it by blowing into then tubing and it may still be no good as it needs too much pressure to activate the switch.
So if the tubing is OK replace the switch.
The dryer will not work. The pause/cancel light is on all the time. If I press any of the control switches the light will blinka few seconds and then return to steady light. I thought the power supply board may be the fault but do not know how to get to it. The 220 volt is okay. The door switch is okay. I have checked other things all okay. Is the pause/cancel led indicating the problem?
How do I get to the power supply? Your help is needed and I thank you if you can help.
