water pump failure after 45 days
I recently performed several repairs on my washer, including replacing teh water pump. The motor shaft was a bit rusty and difficult to remove from the old pump, and the old pump started leaking when I re-installed it. I don’t recall now why I felt I needed to remove the pump. I do recall I needed to be careful in lining up the flats of the motor shaft with the flats on the pump when installing. The new pump has the flats stripped away nearly all the way around. It is also rather difficult for the pump to spin, as it was from the beginning. that is, if I spin my bike tire, it rotates for several seconds before stopping. When I rotate the shaft of the water pump, there is resistance, and no free rotation. Is this normal for a washing machine water pump? I suspect this contributed to the stripping of the shaft, and want to be sure when I get a new one that I am aware of how it should behave/feel brand new.
So I have a replacement water pump, the amount of force to spin the pump is similar to the one that failed. I notice the amount of play that is between the motor shaft and pump receptacle. I am guessing this is the main cause of the failure I experienced. I don’t want to buy a new motor, so I am thinking I will put teflon tape over the motor shaft to get a snug fit. Hope this will prevent the motor beating on the pump receptacle.
Am I setting myself up for disappointment or should this work ok?
