water starts filling, half way, it starts draining
i have maytag LA9357AAE washer. when I start, it starts filling water after it fills up half way, water drains out and water continuesly drains. Please HELP!!!
[SIZE=3]Assuming the motor isn’t running during fill the water is siphoning out and can be caused by a few things.[/SIZE]
[SIZE=3] [/SIZE]
[LIST]
*][SIZE=3] The drainpipe to your house may be too low and you either need to extend the pipe up above the top of the tub or run the drain hose from your washer up high. [/SIZE][/LIST][SIZE=3] [/SIZE]
[LIST]
*][SIZE=3]Someone may have taped the drain hose from the washer to the drainpipe to your house to stop the water from backing up. To fix this either clean out the drainpipe to your house and remove the tape or install a siphon break, part number 201112. [/SIZE][/LIST][SIZE=3] [/SIZE]
[LIST]
*][SIZE=3]If the drain hose from your washer is pushed down the drainpipe too far, this will also cause the same problem. To fix it just pull it out to within about 6 inches of the end of the drainpipe. [/SIZE][/LIST][SIZE=3] [/SIZE]
[SIZE=3]For more on do-it-yourself appliance repair help visit http://www.appliance-repair-it.com/index.html[/SIZE]
[SIZE=3] [/SIZE]
Thanks for the help. It works great now!!!
