I have a GE side by Side. Discovered that when the Icemaker is engaged it has been leaking water from the tube into the water valve. I am having a hard time knowing which part is needed. There see to be 2 water valve units connected together with a brace. One that has the water line attached to it ( that is not the one leaking) and the other one behind it that has 3 tubes coming into it. That is the one that is leaking. The only time it leaks is when I drop the leaver on the ice maker to start producing ice. Can you help me with what part is needed? I have watched a video someone put out on how to attach the water valve. Want to make sure I order the correct one from you.
Thanks!
