So I attached a photo of the temp selections on my washer. During the rinse cycle everything works!
However straight cold will not work at all on wash cycle. Cold valves will open on the warm setting but not when straight cold is selected (wash cycle only) it’s weird that during rinse all functions will work but not on the wash cycle. What is also weird is on the accutemp selection when cold/cold is selected hot water will come in for 60 seconds and stop. I even tried putting the hot line on cold and vise versa but nothing happens
I have replaced the temp switch, hoses and the inlet valve and still nothing. Any ideas on what it could be? I am starting to wonder if it is worth it to try and fix but I don’t want to give up!
