Purchased this unit used and immediately found the motor coupler needed replacing. Now everything seems to operate …except for one thing…when I wash clothes using the NORMAL cycle the clothes seem to be much wetter when I put them into the dryer. I have checked to see if there is any real difference in the others cycles vs the NORMAL cycle and see no difference…any ideas?
— Begin quote from gilkelley;340240
Gill,
Does it drain a full tub of water in 90 seconds or less ?
If not, suspect a weak,damaged drain pump or kinked,clogged drain hose.
If the drain time is in range, suspect a slipping clutch assembly,
[part]AP3094537[/part]
and, or spin tube assembly,
[part]AP3094539[/part]
(one or the other)
here’s some info to help you out,
