WGD8410SW0 Dryer l
As stated in the subject line dryer light won’t turn off, dryer won’t start and it beeps three times when I hit the start button. There is power to the dryer.
I have already replaced the following:
Thermal Fuse
Main control Board
Control Panel
Door switch
Pulley wheel
Drum rollers.
What could be left to replace/repair?
HKFmike,
This would indicate the door open and would normally be something with the door switch or control board. You will want to check the wiring to ensure that there is no damaged wiring.
