I need to repair my Whirlpool Agitator, but there is a different kit for the differnt length Agitator Cams. How do I know if I should order the kit for the Long, Medium, or Short agitator cam? How can I tell which lenght agitator cam I have?
Have your serial number and model number handy and call in your order to APP. Unless there is some reason not, however, just replace the "dogs" and use the old parts and that way you know you have the right ones.
switch recieved has 5 spades the switch i am trying to replace has 6
connectors how do i connect?
— Begin quote from gordon wilkerson;731277
the extra wire comes from the indicator light
What is the switch you are trying to replace?
What are the marks for the terminals on the old switch and the new one?
What is the part number of the new switch?
Are there any numbers on the original switch?
burner control
p l1 l2 h1 h2 new switch terminal
700855k
Are there any numbers on the original switch?2
7945w
— Begin quote from gordon wilkerson;731737
burner control
What are the marks of the terminals on the old switch and the new one?
Which burner?
You did not answer about the old switch marks.
