Whilpool Gold "PF" error
So it been About 6 months since the PF error code came on maybe more so I"m finally tired of not been able to use the oven I shut the power for a few minutes and nothing error code still there the model number is:
GW395LEPS02 what can be rong is the control board or the pannel need help Hungry guy here
If it will not cancel out, then you will need a new control board.[part]AP3777769[/part]
Control panel parts replacement parts for WHIRLPOOL GW395LEPS02 30`` Slide-In GAS OVEN NON-CONV | AppliancePartsPros.com
I recieved the control pannel today installed it and nothing changed the "PF" error code is stil there anything else that I should try
Did you try pressing cancel to clear it out? PF is for power failure. New control should have fixed this.
I tried to press cancel for more than 15 seconds and nothing PF code does not go away
If you are still getting the PF code you will need to check the power coming to the unit, and make sure you have 240 volts.
