Whilpool washer leaks
I have a Whilpool washer mod # LA5243XYW0. The problem is it leaks at the center of the outer tub. I am going to change the "seal" (#21) and the "Gasket" (#16). Question: is there any other part I should consider changing while I have the washer apart?
That should do it, but be sure and check for any problems with the parts as you tear it down. If anything looks even the slightest bit worn, replace it as the parts are inexpensive, but the damage to your machine if you do not replace a worn part in that area can be extensive.
Good luck with your repair.
