Whirlpool Control Panel
I need help figuring out what part I need to order :confused: One day the control panel on my oven would not work, no matter what I pressed it was just not working. The clock was on, but none of the buttons worked. I have gone through all the paper work and trouble shooting guides with no luck (the control panel is not locked) that was the obvious issue. I took it apart myself and could not see anything obviously wrong. Does anyone know what part I need, because there are many within this panel, some a bit expensive? Any help would be appreciated! Thanks D
