HELP!! The pots&pans light and the normal cycle lights keep flashing back and forth between the two and the heated dry light flashes in time with both !! I have tested th heating element for continuity it is fine… tried replacing the control board… no success… any suggestions would be helpful!!!:mad:
Thank you so much…
