Whirlpool Dishwasher door leaking DU910PFGQ1
I am having the same problem as this person:
"I had read that before too. I tried looking at the vent assembly for my model and there didn’t seem to be much to it.
Parts for Maytag DWU5902AAB Dishwasher - AppliancePartsPros.com
Also, it didn’t appear like there was any water leaking in between the door panels anymore. It appears like it’s splashing over the bottom and out from the underside of the door. I really don’t understand why there isn’t a seal there. It seems like an odd design.
Since I have ran the unit without the door panel on, I don’t see any water leaking from the top part of the door and running down. Unless I am missing something, it only seems like it could be coming from bottom and splashing over the lip in the drain pain."
I am not sure how to get the vent off. Do I have to remove the outer door panel to get to the vent in the "inner panel"?
Thank you for any help you can give me.
Glenda
