We have a Whirpool double wall oven model # GBD307PRS01. I noticed today that it started beeping with an E6 F2 code, then went completely blank. I went to the forums to investigate and landed here.
Is there something I can try to troubleshoot the issue first before I replace anything? Do you think this is an issue with the control panel or the control board?
We have black control planel with stainless steel trim. Is part # AP4362220 the correct part number for this?
Looks like your error is an open keypad.
This could be just a dirty/poor connection.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
Also I would unplug/remove power from the unit for 10 minutes or so. The control board may reset.
Hard to say which part is blown as there is no pin-out/schematic for just the keypad so you cannot check it.
I would replace the control board first but it is a crap shoot.
Cannot say if this is the correct part probably it is best to call AppliancePartsPros as the price difference between the different types seems excessive. Also looks like the parts listing is messed up for the control board.
Hi there, I tried the steps in the manual, but ended up breaking the front plastic panel since they were screwed from the inside and different from the steps in the manual. I thought they were just stuck, but unfotunately not. I think the manual is for an older model since the steps did not match. Can someone help me with a link for the GBD307PRS01 manual?
I was so dissappointed about breaking the front panel, that I left it for several months, but my wife is bugging me now to get it fixed. :o Does anyone know a reliable and honest repair shop in Houston/Katy, TX? Should I just contact Whirlpool Appliance Repair?
