What part do I need?
I have a Whirlpool gold double ovens model #gbd307pds5. The ovens aren’t working and is showing an error code of E1 F2 on the panel. I’ve looked up the meaning of the error message and there is conflicting parts necessary to remedy this problem. Do I need the control panel part #8300440 or the microcomputer #4451991? Or both? Thank you in advance for any help.
Here is your parts breakdown
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=gbd307pds5
Here is the tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%204451887.pdf
With some luck you may need neither
Unplug the unit for 20 minutes or so, to see if it will reset
IF NOT
Unplug the unit
Open it up
Clean the edge connector.
  1. Check keypad connector for firm connection (keypad connects to control board).
  2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock
This is what the manual says, but it is a crap shoot. I replace a ton more boards then I do touch pads. Tom
Thank you so much, I will try this first.
Good Luck. Tom http://www.applianceeducator.com
