My whirlpool dryer was running poorly when I moved into new house (needing multiple cycles to dry). I cleaned massive amounts of lint from a very long (30 plus feet) vent run, which solved the problem for a while (2 plus months). The dryer then stopped heating. I replaced the high limit and the thermal fuse. The dryer worked again for several weeks, but recently blew the thermal fuse again. High limit is still showing zero ohms. I checked the vents, and they are still clear. The heating element is not shorted to the frame. The cycling thermostat cycles on the stove top, opening when hot. I don’t know the exact temp. Any thoughts on what might be blowing the thermal fuse? The dryer is 12 years old, but I was hoping to get a few more years out of it. Any guidance would be very much appreciated.
Related topics
Problems with Thermal Fuse | 2 | 1607 | December 23, 2011 | |
Whirlpool Cabrio Thermal Fuse | 2 | 6533 | November 14, 2010 | |
Whirlpool Dryer keeps blowing thermal fuse | 7 | 6773 | February 26, 2021 | |
Dryer keeps blowing thermal fuse even after everything is cleared of any blockage | 2 | 1716 | December 6, 2014 | |
Dryer is blowing thermal fuses | 5 | 7123 | January 9, 2009 |
