I have a Whirlpool dryer model LE5800XMM1 that I’ve owned for about 13 years. It no longer heats up. About two years ago it wouldn’t heat up, and it turned out to be the heating element. Replaced that and life was good. Now same problem. Only this time the element tests fine for continuity. The high limit thermostat also tests good for continuity. Dryer has plenty of voltage going to it, and the timer is working. Dryer will shut off when the time runs out. Anyone have any ideas I can try?
check themal fuse on bulkhead above cycling thermostat =and check cycling thermostat ,with wiring diagram showing contacts of timer set on time cycle use meter with dry off +unplugged see if contacts for heater are closed
— Begin quote from verruckt;20494
Anyone?? getting desperate now.
[SIZE=3]Before going any further you need to check[/SIZE]
[SIZE=3]the main source voltage going to the dryer.[/SIZE]
[SIZE=3]Pull off the cover that covers up the 3 pin terminal[/SIZE]
[SIZE=3]block where the cord is connected to. Check to see[/SIZE]
[SIZE=3]if any of the wires going to the terminal block are burnt.[/SIZE]
[SIZE=3]Then set your meter to check AC volts and "carefully" measure[/SIZE]
[SIZE=3]the voltage between the three terminals. You should [/SIZE]
[SIZE=3]get 240 between the outer two and 120 between the[/SIZE]
[SIZE=3]center and both of the outer ones. If you don’t then[/SIZE]
[SIZE=3]you could have a problem with the outlet in which[/SIZE]
[SIZE=3]you would need to call an electrician. [/SIZE]
— Begin quote from misterfixall;20526
This thermal fuse; is it connected to the timer? I have pretty much disassembled this dryer and that is the only fuse I can find. I tested it for continuity, but it has none. Could this be my culprit? Unfortunately it has no part number on it.
verruckt,
If the thermal fuse (#8 on the [AP3133489](http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=64155&&model_id=252381"]break down diagram)[/URL] is open - it has to be replaced. If the part you mentioned is not the thermal fuse then try to locate it on the break down diagram and post the reference number.
- The part number for the thermal fuse is [URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=3133489&&model_id=252381&diagram_id=64155)
Here are the break down diagrams for the Whirlpool dryer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=64155&&model_id=252381
I started over from the very beginning and followed everything, from power source to the heating element. This time, the hi limit thermostat tested bad. In the beginning, it tested good. I’ve replaced it before, so I know what it is and how to test it. One of the leads was loose, and a little burnt looking which i didnt see the first time. If you wiggled the lead, it would test good, if it was moved slightly it would test bad. So, i replaced it. Plugged in the dryer and started it up. It immediately threw the breaker. My breaker is a double, so it threw the whole thing.
check to see if any of your wires are are toucing another wire or touching body of dryer .are all your wires at correct connections
Also disconnect the heating element,
Then check the resistance of the element, it should be
somewhere around 8-12 ohms.
Then check to make sure that there is “no continuity”
between ether terminal and case ground
If there is then the element is shorted.
[SIZE=3] [/SIZE]
