I have a Whirlpool WGD5800SWO dryer that we have had for a few years now and it now will not start.
It has no power at all.
I have check these items all seem OK.
Push to Start Relay reads zero ohms.
Door switch reads zero ohms
Thermal fuse reads zero ohms
Operating thermostat reads zero ohms (thermostat heater reads 4.8K ohms)
Thermal cutoff read zero ohms
Hi limit thermostat reads zero ohms
Applied 110 V to motor and it spins freely
Door light works.
Not sure what check on the timer swich to verified that it working correctly. I do hear the swich time running but no power.
It seems that switch four on timer switch should power up dryer. I think I should jumper T - W to power dryer. On back side of connection I get 120 V across T -W with timer going and when I push the push to start switch.
I think its the timer switch but not positive. It could still be the motor?
Timer Switch Part number is 3406725. On the plug side of Timer switch I get 120 volts across T -W when I engage the timer switch and engage the push to start switch. Not sure is the Timer Switch 4 is engaging. ANy other suggestions?
That’s just because you seem to know everything already.
I just went through this and the thermal fuse, door switch and start switch are the problem 99% of the time with a non starter.
Here is what I used to educate myself on testing those three things for most any electric Whirlpool/Kenmore Electric dryer when they will not start. Mine is a (WED4900XW1).
Door Switch Replacement (Part 3406107) http://www.youtube.com/watch?v=gWQhuQXa6d0
You can test/bypass the door switch by removing it and passing a wire through the two outer ports in the plug. If the dryer works now, then you know that the door switch was the problem. New part should cost $20-30.
Checking & Replacing the Starter Switch (Part 3398095, 10117655) http://www.youtube.com/watch?v=HSNoURyQVQc
This video does an excellent job of showing you how to test the starter switch by bypassing it, and also using an ohm meter to test the internal circuitry. Blue to Blue should have zero resistance when the button is depressed.
New part should cost $30-45
