I’ve replaced the fuse, limit switches, thermostat and had a parts house test the heater could. Has air but still no heat. Tested continuity on all parts. All are good. Any ideas what to do next?
- test for actual 240 volts across L1 and L2 at the terminal block
- check to see if the centrifugal switch on the motor is passing 120 volts to the heating element
