Just trying to check myself. The non resetable fuses test good. No heat electric dryer. Could it be the element or the termostat?
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=252462
I am assuming that you checked the thermal fuse (Item 7 in Section 3) with a meter and that you disconnected one side of it when measuring. This prevents reading an alternate/parallel circuit path.
Yes it could be either of the above, with the element being the more likely.
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit’s terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord.
Be careful 240 volts is lethal.
If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Heating coil, should be 10 ohms approximately.
Thermostats and thermal fuse all should be 0 ohms.
Be sure to disconnect one side of and device you are measuring this prevents reading an alternate/parallel circuit path. Also use your most sensitive ohms scale.
There is a good Sticky at the beginning of this forum on meter usage.
Thankyou sir. I went ahead and ordered a new element and thermostat for the cost I also figure it has to be one or the other.
denman said:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=252462I am assuming that you checked the thermal fuse (Item 7 in Section 3) with a meter and that you disconnected one side of it when measuring. This prevents reading an alternate/parallel circuit path.
Yes it could be either of the above, with the element being the more likely.First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If OK
If OK
If OK
Thermostats and thermal fuse all should be 0 ohms.Be sure to disconnect one side of and device you are measuring this prevents reading an alternate/parallel circuit path. Also use your most sensitive ohms scale.
Sir; Thankyou The element was bad received the part yesterday. Installed within a hour so far so good. Thanks
Thanks The element was bad. Installed yesterday so far so good.:rolleyes::rolleyes:
