I have a Whirpool DU1100XTPB3 dishwasher with the "Clean" light blinking and the dishwasher won’t run. The owners manual says the clean light blinking means check the heating circuit. Would this indicate the heating element has failed or would it be in the circuitry?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=DU1100XTPB3
You cannot tell without testing.
Check the heater resistance.
Check the hi-limit thermostat.
Check the door switch, that is closes and is 0 ohms when closed.
Check the wires from the heating element to the control board and to the door switch.
If all OK then it is the control board.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
