hi, my 8 year old whirlpool du945pwpq0 dish washer stopped working. no light at control panel. i checked door switch , thernal fuse they both ok in terms of continuity and 120 ac. i replaced control panel still no light , i am returning control panel and will try control board . what could be probelm ? need help.
I had the same issue with my whirlpool, no lights and would not start. To correct this I just slightly bent the metal bracket(top center) which activates the door switch. This corrected the issue for me. Hope it helps you too.
