Hey everyone, i have a Whirlpool Duet dryer WED9151YW0 that has different time settings depending on the cycle you have it set for. Normal is 35 minutes and Timed dry is 40 minutes. I like to use timed and change it from 40 to 50 minutes at the start of each load. I would rather have extra time and have the moisture sensor shut it off.
Is there a way to change the default time setting in Timed dry mode to 50 minutes so i don’t have to manually do it before every load? I’ve searched all over the internet and haven’t found the answer to that, although i’m sure it can be done somehow.
