Whirlpool Duet dryer
Dryer will not turn on. The control lock light is dimly lit up. The dispaly shows two faint dashes.
We are dealing with probability here, with the interace board (the one with buttons) being the logical culprit. Unfortunately it could be the control board, or even both.
As you have probably guessed, a service tech has the boards in the truck and merely changes them out until the problem is solved, but you do not have that luxury. If you want to try to fix it you will have to try a board at a time, but I think it is likely the interface board will solve your problem. If not you will have to go to the control board.
Since both of these are pretty costly, you will need to think about whether or not try the repair. This is a pretty good dryer when it works, so I would go for it.
Good luck, let us know how it turns out.
It was working when I would shut the power off, wait 30 minutes and turn the breaker back on. The dyer would run the cycle and then you would have to reset with the breaker.
I see several people have had this problem with the control lock keeping the dryer from starting. Holding the button 3 seconds and unplugging to reset doesn’t work. What was the fix? :confused:
