My electric duet dryer runs but no heat. What could be the most likely issue?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=gew9250pt1
Here is a manual, although for an older unit it should be close to yours.
http://appliancedigest.com/index.php?/files/file/325-l-69-whirlpool-duet-gas-electric-dryers-service-manual/
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
First I would check the power to the unit.
The control board, motor use 120 but the heating coil requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
If power is OK I would unplug the unit and check the heating coil, the thermal cut-off and the hi-limit thermostats for resistance.
If the thermal cut-off is blow (open) then there are other things you should check before replacing it.
Got it, heating element was broken
— Begin quote from denman;406544
[L-69 Whirlpool Duet Gas & Electric Dryers Service Manual - ApplianceDigest.com](http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=gew9250pt1"]Replacement parts for WHIRLPOOL GEW9250PT1 ELECTRIC DRYER | AppliancePartsPros.com[/URL]
[URL="http://appliancedigest.com/index.php?/files/file/325-l-69-whirlpool-duet-gas-electric-dryers-service-manual/)
If OK
If OK
