Whirlpool Duet F70, F71
I have replaced the User Interface and the CCU and STILL getting F70 and F71 error codes ( I have already checked wire connections) The drum turns which based on other posts means that the problem isn’t the motor control board but does that mean that the motor control board could be the issue? At this point the MCB and the door latch switch are the only parts that haven’t been replaced. Anything else I should check?
Thanks.
