Whirlpool duet sport leaking from door when "Clean Washer"
My Whirlpool duet sport washer will leak water from the door when I use "Clean Washer", what I found on the internet is
Some people posted below:
[LEFT]condition:[/LEFT]
[LEFT]In some instances, small amounts of water may leak through the door, typically only when using the CLEAN WASHER or
DELICATES cycle.[/LEFT]
[LEFT]cause:[/LEFT]
[LEFT]In some units the door glass may not be making good contact with the Bellows near the 11:00 O’clock position.[/LEFT]
[LEFT]resolution:[/LEFT]
[LEFT]The field repair for a unit with this condition is to order and replace the "Panel, Front"
Order the replacement part below using the normal ordering process.[/LEFT]
[LIST]
*]White(NNN) NNN-NNNN/li>
*]Black W10128427[/LIST] However google also gives me this link:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/a9c27c267a3fa32785256a45005190c7/4048ac9ad5177883852574500049997b/$FILE/duet_f20_code.pdf
which mentions
Serial number starting with HLT WTW800 Series Duet Sport
The field repair for a unit with this condition is to order and replace the Bellows ( part number 8540952)
My question is they seem to be different parts but for the same condition, so which part should I order for my washer?
My washer serial number is HLW4042054
This is typical Whirlpool for this model and I cannot give you a definitive answer.
I would replacing the door panel first as it is a lot easier to do and I think more likely the cause of the problem. If you order from this site and that part does not fix the problem you can return it.
